water faucet in galley
Apr 9, 2014
33
macgregor 26x Avon
thanks, I did find out that it is made by "whale"..., checking at west marine as well, will
buy one if someone has one though '97 26x...
Jul 7, 2004
8,498
Hunter 30T Cheney, KS
Mine is worn out also but I have not found a direct replacement. Which means more mounting holes.
Jul 7, 2004
8,498
that's what I was trying to do, match the holes, but I might put piece of wood over and recut...
That's a good idea. You can also buy an HDPE (?) cutting board and use the material instead. It will be match the faucet and sink and zero maintenance.
I think I may go to a 12V faucet this time.
chp
Sep 13, 2010
434
Hunter 280 hamilton
For what they charge for a manual faucet hand pump I went with a Jabsco electric pump and faucet. Wife likes to just push the button for water.
kito
Sep 13, 2012
2,011
1979 Hunter Cherubini 30 Clemmons
I may be wrong but faucets are either 4" or 8" on center or just a single hole mount. No need to buy a "marine" faucet for 4 times the price. I got a nice 8" on center faucet with 6' pull out sprayer for $30 on Ebay. Your water pump turns on when it senses loss of pressure. Nothing magical going on with a marine faucet.
Apr 29, 2010
209
MacGregor m25 Erieau, Ontario, Canada
Try your neighbourhood RV dealer. Should be cheaper there than West Marine. Hopefully, there's no salt water in the boat so, regular RV/trailer stuff should work.
This should apply to sinks, stoves, cushions, internal paints/varnishes as well.
