Great catch!!. Never had a leak from the screw holes in the hood that covers the lines running under the deck on my Hunter 386. Always disliked the hood because it trapped dirt, and promoted algae growth which damaged the lines and was an annual maintenance item to clean inside it......issue went away when the boat was sold.We had the same problem with our 1998 H376. The final solution was re-bedding the screws in the hood that covers the lines running under the deck. No more leaks after 2 years.
How about securing with (2) sided 3M tape they make some really strong stuff.Yes, we have not screwed ours back down and the large one slides in towards the companion way. We were in pretty rough water last week and realized not a good thing to leave unsecured
Husband read somewhere that someone had epoxied dowels in the holes and screwed cover back down. He is still mulling that one overI don't think the cover plates are a point of water ingress on our 376 (yet), but I need to remove the cover to run some new lines from the mast back to the cockpit. I noticed that the top panel seems to be wood cored, as is the deck. I was planning on over-drilling both, filling with epoxy, and drilling/tapping the deck side for the screws (trying to be careful not to drill all the way through the deck portion). Hopefully they will both avoid water ingress and protect against any chance of wet decks.
That said, someone floated the idea of just filling with epoxyband not putting any screws back in. Has anyone else done that? Any issue with the cover plates slipping or moving?
