James
I have a '85 28.5. Any water that gets on the floor of where the engine is, has a tendcy to linger for a very long time before it drains to the bilge. There seems to be quite a bit of tunneling going on from all the different sections under the flooring to the lowest section where my bilge is. In all those sections water seems to accumulate a bit..to eventually pass on only after a while. How do you clean and maintain these channels for water passage! Should water not be building up and hanging out at all....that is sort-of my guess! I also only have one power bilge on board...should I have a back-up???
