Water (drain?) smell on Hunter 33
Jun 13, 2024
12
Hunter 33 Toronto
I recently purchased a 2008 Hunter 33. We've started noticing some smells (sulferish) around the galley sink. We initially thought it was an issue in the drain, and that may be part of it. Today i took samples from the hot/cold taps in the galley and head (all water cold because the hot water heater isn't on), and noticed a sulfer like smell from the water itself; strongest from the galley hot tap i think.
I was thinking a system flush/cleanse would be step 1 for solving the problem. A bit of research led me to this page: https://yachte.co/boats-water-smells-like-rotten-eggs-and-sulfur/ that talks about how to do a cleanse as well as a couple of other possible causes of the odour. Because the boat was sitting largely idle for several months while it was on the market, it's not all that surprising that things may have started to grow in its water system, especially as we started to encounter summer temperatures.
Not forgetting the drain factor, I've seen other posts here, including some from Headmistress Peggy Hall, that talk about how to deal with drain smells. And have also see that sometimes replacement of hoses may be required.
This is looking like a fairly straightforward cleaning challenge, assuming the system flush/cleanse solves the problem. But if anyone has gone through the process of cleaning their water systems and has advice on how to make sure the process goes smoothly and/or the effort is a success, please share your thoughts here.
Dec 2, 1997
9,011
- - LIttle Rock
If the issue is ONLY in water from your water heater, that's likely to be a need to replace the anode in the hotwater tank. Whether you can do that depends on whether there is a replaceable anode in your hot water tank. The least expensive water heaters have anodized steel, or aluminum tanks...no replaceable anode. As they age, that anodizing wears off, resulting in the rotten egg odor from it. Unfortunately the only cure for that is a new water heater.
Before jumping the the conclusion that IS your only solution, contact your water heater mfr for their advice.
As for maintaining the entire fresh water system....you'll find complete instructions for recommissioning it in a "sticky" (permanently "stuck" post to make it easy to find at the top of the posts) at the top top of the Plumbing and Sanitation forum. This should be done as part of spring recommissioning every spring and/or any time a boat has sat unused for an extended period. I'm always glad to answer questions.
--Peggie
