Hello people of Yamaha 25MKii and YSM8
For long time didn't had any problems with the old YSM8
Recently was working with it and suddenly the sound changed and i rapidly noticed that the cooling water had stop flowing...
Was quite easy to realize that something was wrong with the water pump... impeller was more than dead...just the central pin had survived (after 6 months working - i had it changed last time i had the engine checked).
Was quite straightforward... went to get a new impeller, removed the water pump, replace the impeller, checked the water flowing from the pipe connecting to the seacock...everything was ok...
Installed the new impeller...installed the pump...connected the belt...everything ok...
However... the water runs...and reach the engine...i removed pipe by pipe to check if any was dry but all had water...
Only the water doesn't come out to reach the elbow!
Is it possible to be something wrong with the water pump...not making enough pression to send the water up and out?
If so...what need to be done? Change to a new pump? And if so, any suggestions?
Spent the whole afternoon getting greasy... and very disappointing!!!!
