Questions for Peggy.I have just completed a (Peggy) textbook installation of a new head, tank, hand pump etc. Previous owner had piped a new holding tank w/o vent loops, tank was small, head was old, etc.New Raritan PHII has ~8-9' to vent loop, which I calculate as ~3+ qts. Also ventilated loop between pump & bowl about 3' above head on bulkhead behind head. Also tee'd off sink drain to raw water inlet for fresh water feed to clean system. New tank is 25 gallon. Hose is white Sealand $$$ OdorSafe.Raritan says dry pump will only evacuate bowl, not move material. Raritan says ~7 oz. per pump. Tested system from dry, after getting water to bowl it took ~25 pumps to get water to the tank, ~5-1/2 qts according to Raritan. Tried dry pumps & they still seemed to be moving water to the tank.So, multiple questions:Could we, in fact, do a series of wet then dry pumps to move material (liquid at least) to the top of the loop with less water?How necesary is it to get the "good stuff" all the way to the tank w/every flush? Could we flush with 4-5 wet, then 3-4 dry, during the day, then make sure everything gets to the tank last flush at night?Other suggestions?Thanks!
