If I have a following sea condition water comes in through the discharge and slowly fills the bilge of my 1983 Catalina 27 through the bilge pump. Also when i run the bilge pump and then shut it off the residual water in the exit hose slowly runs back into the bilge. There is a looped riser in the hose just forward of the transom which should prevent back-up but it does not seem to help. I have also replaced the bilge pump. Any suggestions would be appreciated.
