Not Sure
My guess is that the answer is yes, but if it were a significant problem, I'm sure we would have heard about it by now. I have inspected a couple of Mac 26's that have been kept in slips and the hulls and especially rudders didn't fair very well from an osmotic blistering stand point.That's why we applied an epoxy barrier coat before we put SeaQuell in a slip.One thing to consider is that the water ballast tank may actually reduce the risk or severity of blistering on the outside of the hull, as one factor in osmosis is the differential pressure across the substrate.Naturally, the differential pressure across the fibreglass will be less if there is static water pressure on both sides.However, this is just speculation on my part. There is certainly more likley to be a risk of osmotic blistering on the inside of the hull, if there is lying water. I have heard of various sailboat brands blistering in the bilge where standing water is often present.So the answer is, "Could be, but not a significant problem worth worrying about."
