I wonder the same thing as Randy
The inside surface area of the ballast tank is going to be significant - and the tank is designed to hold water, not pressure. Say, for example, the tank was 8' long, 2' wide, and 4" deep (internal measurements) - that would make the surface area of the top side of the tank all by itself 2,304 square inches (96" x 24"). Even at 1 psi, that is 2,304 pounds of total force being applied outward from inside the tank.In fact, with a high volume, low pressure inflation pump, and your ballast valve fully open, you probably wouldn't even reach 1 psi effectively because the outflowing ballast water is acting as a "relief valve". However, if someone was to close the ballast valve when the tank was about half full (full surface area of the top side exposed inside), I would think you could build up dangerous pressure inside.On large ships, when taking on fuel (or water), there are specific rules for how much incoming pressure you can have based on the size of the air outlet vent on the tank - I have seen the results of a few large tanks that were filled too fast or filled with the air vent secured - the results were, shall we say, "spectacular".I'm not necessarily saying I would not try this method, but I would be extremely cautious about making sure the outlet remained open and free of obstructions.- AndyS
