K
Kelly Fitzgibbon
Water Ballast LeakWe have had a '94 Hunter 26 for 2 1/2 yrs. It always seems to have water under the sink areas and in the bilge area after sailing when the boat has heeled hard. I just took a cruise from Portland OR to Astoria, OR. After arriving we had water in the seat bins around the table, under the sinks, in the bilge. I had to stay awake all night bailing water, since the crappy bilge pump was to weak to pump the water up the hose and the water kept coming in. I must have dumped 30 to 40 buckets. I put the boat in the Ilwaco boatyard. Repaired the ballast valve gasket that was shot. Made sure the ballast tank was empty, then I shut the valve tight and filled the ballast tank from the inside of the boat with a garden hose. As soon as the tank was almost full water started showing up in the seat bins and also running down the side of the hull somewhere into the bilge area. There is no access to the area under the floor that I can find. We had to trailer the boat home. I hope someone can give me some ideas on what to do. Thanks,Hazel Dell Kelly
