G
Greg
I read an article in the archives about putting pepper in the the ballast tank to stop slow leaks? Does this acually work?The problem i am having is water in the bilge and i have no idea where its coming from. I have checked numerous areas and all seem to be fine.Rudder hardware, motor mount, ladder bolts, sink and bilge drains, anchor locker box, resealed rub rail, checked centerboard bracket bolt,potta potti screws, step mounts, outside table mount, and probably some other things i cant think of at the moment.The only thing left is the ballast tank and the lifeline stensions. I'm pretty sure its not from topside since it hasnt rained alot lately and when i check the boat every other day i have about 2 to 3 gallons in the bilge. I installed a new 500gal bilge pump on the battery side since the factory one was no good and the water always collected on the opposite side. I used the same through hull and just ran an extension hose around to the other side. Works great and has been gettin alot of use too.Anyway-- i am out of ideas and tired of lookin. I cant think of any other place where water can come from. I havnt tried the food coloring trick yet but have noticed that when i open the ballast tank valve the tank fills with more water. Any ideas??? I am thinking about dumping some pepper in the tank to see if that seals up any slow leaks i may have.
