Hello, I am helping a friend on a Hunter 28.5, which has bad odor prob due to water, and an earlier holding tank hose leak. I have fixed the hose leak, but can not be certain that I have gotten all water out from under the liner beneath the cabin sole. The bilge pump is in this liner, but there is/are ways for water to get below the liner and bilge pump. This is the prob.
After thorough cleaning of all areas accessible under the sole, and then sailing (and heeling) , more very ugly water comes into the liner from below. There are some holes in this liner - like limber holes - but do not drain to bilge. I have inserted a vacuum pump hose (to which I fix a small diameter hose) into these holes to suck out this water and accumulation. But not sure that I get it all.
Have considered but am reluctant to cut holes in this liner pan.
Any advice would be appreciated re this matter -
- getting access to the area below the liner
- has the boat (1986) been modified - hard to believe that a boat would be made in which the bilge pump is not in the lowest part
Right now I am considering just cleaning and vacuuming all the cavities, and putting some disinfectant into the cavities and then vac that out.
Any advice, comments would be appreciated.
