water and holding tank "gauge"
Hunter 410 Grand Rivers, Kentucky
Does anyone know where to find the "gauge" for water and holding tanks for 2002 Hunter 410? The push buttons are worn out. If not. any suggestions for a proper replacement?
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
On my 2000 the tank sensors are wema. I don't have push buttons so may not be the same. I think Hunter switch to Snake River. Are your tank sensors strips on the outside of the tanks? If so it is probably a Snake River system.
Jan 12, 2011
930
Hunter 410 full time cruiser
I don't have any push buttons either. But I would think that if you pulled one of the buttons you could match it to something (look for a number on it and do a search and it may lead back to to the manufacturer).
FrankT
Jun 11, 2004
37
Hunter 410 middle river, md
I replaced the monitor. When it failed several years ago. My unit was made by Snake River Electronics which Hunter simply put their name on.
At that time Snake River changed to Tech Edge manufacturing (514 367 1216. I purchased a replacement monitor from them and it worked fine.
Below is the link to their web page and the replacement tape.
I would give them a call, tell them the name of your unit and the problem you have
Hope this helps.
Frank
https://tankedge.com/accessories.html
