Doug Margison
Fortunately my wife and I close the through hull valves to our boat when we go home after a sail or weekend on the boat.Last week when we got to the boat and opened the through hulls we noticed the water level coming up in the head even though it was on "Dry Bowl"Don't worry I told my wife, the head is original equipment and the top of the bowl must be above the sea level so it won't overflow. We pumped a few times to clean out any debris, then pumped it dry. Low and behold the water just kept on rising and rising, reached the top of the bowl and started to overflow. Whew, quickly we shut the through hull.Then I went and checked the level of the seawater relative to the top of the head - top of head 2" below seawater level. Remember this is original installation.This weekend we are going to rebuild the pump, and modify the water intake hose to have an anti siphon tube extening up to 8" above seawater behind the head so if, heaven forbid, we forget to shut the thru hull and the seal in the pump fails the boat won't sink. This is a serious matter that we understand has sunk many a boat, so boaters BEWARE. If this article potentially saves a single boat it is worth it.
