I have a Mk 1 30 Catalina and the usual small-ish anchor well. I have it pretty filled with deck-mounted Pro 1000 Windlass and 200 ft of rope and 100 feet of chain. I have very little space left but think I can put in a deck wash down system with a little work.
Am thinking of installing the pump under the vee berth, then the outlet hose up thru the small cubby cabin at the head of the vee berth, sufficiently sealed from water intrusion of course, then up into the base of the anchor well, running the outlet from the pump thru the anchor well via a hard tube, pvc lets say, to protect the outlet hose from chain damage, then to a deck fitting that I can screw the hose to.
Anyone out there have a similar installation they can verify mine to?
