Sail trim and reefing
While my wing-keel H23 is not identical to the water-ballast H23.5, there are some basic techniques that can still be applied regardless:1) do not be reluctant to reduce sail area. If the thought of reefing the main crosses your mind, go ahead and do it right away. Even better, put in a reef before you leave the dock if it looks like it's going to be very windy. It's easier to shake out a reef on the water than to put one in. As mentioned earlier, Hunters have powerful mains and should be reefed earlier than most other boats.2) If reefing doesn't help the situation much, drop or furl the jib. Don't worry about what the "purists" would say; your comfort and safety are more important. Hunters sail fine under main alone.3) work on your sail trim. The main can be depowered by tightening the outhaul, cunningham and backstay. Some of these controls are more effective than others and are dependent on the boat to some extent, so you will have to experiment a little. Also make sure that your topping lift and vang are loose if you're going upwind, otherwise the other controls won't work. Tightening the sail only works up to a point, because it also reduces twist, or the ability of the sail to spill wind.4) use your main sheet and traveler more. You may have to ease the sheet or drop the traveler in the puffs to keep the boat on its feet. You can make good boatspeed upwind with the jib trimmed properly and a big bubble in the main. It looks ugly but you will be safe and comfortable.5) Increase the twist of your sails to spill the wind off their tops. If you have adjustable jib leads, pull them aft. This tightens the foot of the jib and opens the leech. Pull the traveler UP and ease the mainsheet to keep the boom in position for proper trim on the bottom of the sail. This reduces the downward pull of the mainsheet and allows the boom to rise a bit, which opens the leech, increases the twist of the mainsail and spilling the wind off the top of the sail. This reduces heel while still giving you plenty of power to work the boat through the waves.6) practice. Go out on windy days with just the reefed main and add more sail as your confidence level increases. It's the only way to develop the skills and experince to sail under less than ideal conditions. Who knows, you may need them one day.Good luck and happy sailing!PeterS/V Raven (Go Baltimore!)
