I have a walter V drive with a MD11c engine. The coupling between the drive shaft and the transmission is giving me some problems. The three bolts sheared off at a bad time and after they were repaired the shaft keeps slipping out of the coupling. There is only a key and one set screw. Anyone with some used parts?? My prop seems to be too large as the maximum RPM's is about 2250 giving a hull speed of about 6 knots. The boat is a pearson 323 1980.Tom
