Walker bay oarlocks
Aug 26, 2014
4
Walker bay 8feet Belfast
This may be a small matter to most of you but if you use a Walker Bay dighny you DO NOT want to loose an oarlock!! You will find you cannot replace one , or a pair, without spending a lot of money and getting the whole installation kit. I cannot find any other oarlock that will fit a walker bay!
Jan 30, 2012
1,150
Nor'Sea 27 "Kiwanda" Portland/ Anacortes
Consider having your local store check the SeaDog wholesale catalog. SeaDog is in Everette WA. They are a very reliable supplier of many products - but they are wholesale so you have to inquire via your local retailer.
Anyway - last year I purchased three pair supplied by SeaDog and they fit Walker Bay just fine.
Be sure to measure the oar shaft opening accurately (be generous) and also double check the pin diameter too.
Charles
RAD88
Dec 15, 2008
163
Hunter 30 Glen Cove, NY
A quick search of Ebay turned up a set for $12 + shipping. Also -almost any oarlock can be used on a Walker Bay but I prefer the offset style of the Scotty oarlocks.
Aug 26, 2014
4
I should have persisted with eBay I guess. I searched but d
I should have persisted with checking eBay. When I looked there were non listed. Since I need my dighnyy I gave up and ordered them. WHY would they not have supplies of them wherever they sell the dighnys? Thanks for writing.
Aug 26, 2014
4
What is a "Scotty" oarlock?
I have several pairs of ordinary metal oarlocks and non of them will fit into the Walker bay oarlock openings.
Not sure about the name "Scotty" type but guess they are the offset type as used by walker bay
Aug 26, 2014
4
Re: I should have persisted with eBay I guess. I searched b
No, most oarlocks (non that I have found) will fit into the walker bay oarlock opening.
