I have a 1997 Hunter 450 with a 78 HP TMD22 turbo diesel. I have owned the boat for 3 1/2 years. Until a few months ago, the engine ran like a champ and started without exception incredibly fast. You couldn't get your hand off the key fast enough it started so quickly. Then a few months ago the engine began shutting down sporadically as if running out of gas. It started on a hot day but has done it under many conditions. It will always restart with lengthy cranking but will die again sometimes after only a minute or two, sometimes after 10 or 15 minutes. It is also inconsistent in that since the symptom started, the engine has also run without problems for a few weeks. Then the problem started again. I have changed the 2 fuel prefilters as well as the main filter after the lift pump. I saw no water in the filters and they were pretty clean. I just changed the lift pump itself thinking the diaphragm had possibly failed. Apparently not the case since it ran for about 10 minutes, then died right after I changed the pump. It seems to me to be a fuel supply issue but I need some ideas here. I am not a mechanic. I'm a parts changer! FYI the genset engine runs fine with no issues pulling off the same tank but a different, dedicated fuel line. Also, I use this boat (and run the engine) literally 150 days a year so the fuel is not stale. Anyone have ideas to offer? Thanks!!
