the Volvo 2003 on my 88 B350 has a water hose going to the shaft seal. Is this necessary or can it be discarded when the new Volvo D130 is installed?thanks,Bob Gales
is the purpose of the hose to the shaft seal. It will probably burn up without the water cooling. The PSI shaft seal does not have the cooling line, but has provisions for burping the trapped air from the seal. Unless such provisions are in place, you need the water line.
