Jim Cook
The first contractor I hired to do my bottom 2 years ago painted bottom paint on my VolvoPenta S110 saildrive (I have a 1974 Volvo MD7A 13hp deisel). The result was that the saildrive disintregated (after about 1.5 years)and the lower half "fell off". I hauled it out last November, did a bottom job and replaced the saildrive (not the transmission on top) with one I got from a salvage yard. When I took the old unit off, the transmission was full of white-ish glop which I was told was oil/saltwater mixture. I cleaned out every bit that I could, before putting it back together and back in the boat.After sailing home (in November), I found oil had leaked from somewhere. I have to assume it is from the tranny because the engine never leaked. A local marine mechanic said it may be the seals in the tranny, but I couldn't find the source location of the leak, just oil around the bottom.Do you have any advice about locating the leak, probable causes and possible fixes?Thank you for your time.Jim Cook"Dream Chaser", 1974 O'Day 27
