Hey guys, I'm getting going on the balboa 26 restoration and I've come to the engine. I managed to get the lines all bled and got her warmed up enough to crank this morning. She runs pretty good from the way it sounded. I was pleased. Although, I didn't have water sucking into the engine cooling passages so I shut her down. I tried several things then wound up using the garden hose to pump water straight into the cooling passages where I managed to have a nice stream flowing out the exhaust. I thought great I've got it now. But here's the thing. The engine is getting water in the oil crankcase when I crank it up. Is there a good place to start looking for a bad seal or bad head etc. or is this simply my dumb fault for using a garden hose and filling the exhaust port with water...leading to the crankcase filling up.
I'll also add. When it's running you can pull the dipstick and it will quickly fill with water then overflow.
Of course once I saw this I quickly Shut her down and won't try anything until there is fresh oil and filters in place.
Any help on the cause of water into te oil is greatly appreciated. Thanks in advance!!
-tyler
-tyler
