Have had a Gori 2 blade folder on F310 for 12 years now. Gives about a knot less under power verses a fixed 2 blade but gives about a knot more under sail. The pins that hold the blades in place can wear causing a blade to fall off.In most cases I've seen this has taken out the strut. If You race the folder is the way to go.
