I am finally going to install the Blue Sea 8 Position DC Breaker panel, replacing the stock O'day panel. Bought the panel 2 years ago but now I have added a few electrical things installation is top on the priority list.
I have read Maine's articles on battery monitors and decided on installing a analog voltmeter. I understand it will only be accurate after the battery as rested for 24 hours. I plan to use it to check the battery charge state when I first get to the boat.
Our normal sailing plan is 2 to 4 hr day sails using power only for auto tiller and GPS power. The battery goes in fully charged when the boat is splashed and has lasted all season only being charged by the OB for the 45 minutes we use the OB per trip. (out to the sails up area and back)
I'm hoping the volt meter will give me some warning if I start to drain the battery lower than the OB can recharge.
I bought the Blue Sea Analog Voltmeter. The wiring instructions show it wired to the battery positive and the negative to a negative bus bar. It has a switch to select 1 of 3 batteries.
I believe I should run the wires directly to the battery, not to the battery switch, to avoid voltage drop in wiring and connections.
What the diagram does not show is whether you put in a switch to turn it off or on. I can't imagine leaving it on all the time.
Here is the link to the instructions.http://assets.bluesea.com/files/resources/instructions/9310.pdf
Thanks
Thanks
