Vision32 Yanmar 27
Feb 23, 2014
3
Hunter Vision 32 Puerto Vallarta
Recently had some engine work done.
The electric speedometer is not working.
Any ideas where and how to trouble shoot?
Jun 11, 2011
1,243
Hunter 41 Lewes
They usually run off the alternator. You should get a wiring schematic and check each connection in the line. If they were in the engine compartment, I would start at that end.
Nov 6, 2006
10,257
Tachometer
That engine's tachometer is driven from a "tooth counter" pickup on the flywheel housing. It is just aft of the cylinder head and has two wires coming out. The usual problem is a bad connection in this counter circuit. The bad connection could be at the counter pick-up or in one of the two multi wire plugs between the engine and the tachometer itself. I've attached some information on the tachometer.
14
Hunter Vision-32 Puerto Vallarta MX
Great Info
Claude
Thanks for your help.
This is exactly what I was looking for.
Richard
