Vision Keel
brian
Please advise, is the vision keel a separate bolt on apendage or a permanent glassed in part of the boat? Secondly ,is the mast grounded to the keel?
J. Hrab
Vision keel & mast
From my own boat I see that the keel is bolted and underneath is glassed in. The mast rests on the keel and has a pin that holds in place (along with a collar on the roof. Mast comes out very easely when the pin and collar are removed. Jean Hrab
Jim
Vision 32 Mast
Brian, The mast and Keel on my Vision 32 are attached together with a no. 6 copper wire.
N
Noel Black
Vision keel
The Vision has an external bolted on cast iron keel. It is grounded to the mast by a small gauge wire from one of the keel bolts. Noel
