Vision 32 Mast step
17
- - Sidney
Does anyone have a drawing of how the mast is stepped to the keel? My mast is not centered in the lower collar -- there is about a 1/8" gap at the front of the collar, and none at the back. There does not appear to be any movement in the mast, and it feels secure. The seal at the deck also leaks (rain water runs down the mast). Before I have the mast lifted, however, I would like to know precisely how it is mounted and locate replacement seals. I have sent emails to Hunter, but so far no response. Can anyone help?
Rick D
Jun 14, 2008
7,206
Can't Help With The Mast Step....
...but I sealed my leak with just some marine caulk around the mast boot. It's been too long for me to recall the mast step layout; never had the mast out. I seem to recall a set bolt that went through the step and into the mast. Take some photos and post them here when you do it so other owners can have a heads-up when they encounter the same thing. Good luck, Rick D.
