Vision 32 Jiffy Reef
6
HUNTER 376 Panama city
I have a 1989 Vision 32. It is set up from Hunter to have two Jiffy Reef points fairleaded back to the cockpit. When I bought the boat the rigging was not installed. I have been trying to get info from Hunter but have not had any luck. I would appreciate any information you can provide so I can re-rig these two lines
thanks
Dave Sullivan
850 819 4163
george.sullivan@navy.mil
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
If it is like my 30T you should have two blocks at the end of the boom and two at the mast. You should have two blocks at the base of the mast and a clutch on the cabin top by the cockpit. You run your lines through these blocks. When the line exit the back of the boom you take the line up thorugh the reef point in the sail leach, then down on the other side of the sail to an attachment point under the boom. Put a bowline there and you are set. One line goes to the lower reef on the sail and the longer line goes to the second reef point on the sail.
When reefing I attach the luff ring in the rams horn to complete the reefing attachment points.
Rick D
Jun 14, 2008
7,187
To Add To Sailgunner's Description...
...and forgive me, it's been ten years. From the clutch, the line goes through the organizer to the (double) mast base block, up through the eye on the mast, through a block on the mainsail reef point, down through the eye again to the top sheave of the same block, up to the sheave on the front of the boom, through the boom to the (same) sheave on the back of the boom and then up through the same reef point cringle as the luff and down to the boom bail closest to the cringle.
I sure hope this makes sense since I may be confusing it with my 40.5 which is very similar. What I don't know is if there is a double block system inside the boom. I don't think so but it's been too long to recall accurately. Maybe someone has better info. Good luck!
Ed D
Nov 22, 2009
39
Hunter Vision 32 Jacksonville Florida
Reefing Vision 32
The people who made this boom for Hunter are E.B Spars located inHudson Quebec close to where I grew up The phone number is 514-327-7277 web site www.isomat.com email sales@ebsopars.com They were very helpful for me They will send you a drawing of the internal setup inside the boom
Ed
Ed D
Nov 22, 2009
39
Reefing lines Vision 32
Dave
Look at the replies to my posting dated 11-22-2009 currently on page 15 maybe 16 buy the time you get in Ron Relea sent ma a drawing which may help
Ed
