Tom Payne
Hey Vision 32 Owners!!!! I have a question regarding my Bilege Tank System. There are four wells inside the cabin. My Vision is set up with the two middle wells being wet, holding two to four inches of water. The aft middle well has the Bilege pump. The forward middle well has a hole to allow the passage of water between the two wells. My question, Can I dry out the forward middle well by plugging the hole with a transom plug and use the area for storage.One concern I have is the Mast grounding wire that attaches to the keel in that well. I believe the wire is to draw a lightning strike through the mast, through the wire, into the keel, and out into the water beneath the boat.Do you think Hunter intentionaly kept that well wet to assist in directing the lightning strike to all the keel bolts in the well.Your knowledge and assistance is greatly appreciated!!!Daddy's Dream
