Vinal Lining Replacement
alibi
Sep 12, 2007
14
- - Atlantic Highlands NJ
Gentelmen, I recently purchased an first 285 with some existing problems. There are some water leaks from various port hatches and light windows which over time have been negleted and have caused the vinyl lining to become water logged and seperated from the glass hull. I will need to remove the old lining and replace it but I am hopeing that I can purchase the lining already cut out to the specs of my boat from Beneteau. Can someone comment on the way to attack this??? I am trying to avoid a wallpaper type installation since the cutting of the vinyl, exactly to specefic measurements and proper adhesive are crucial.
alibi
Sep 12, 2007
14
F
FMcNeil
liner and other challenges
I had a F285 for four years and found Beneteau Service dept to be very helpful. They even sent me small parts, like those barrel nuts/ bolts that hold the windows in, at no cost. Try them first if you haven't already. They even had the replacement F285 cabin top decals which most owners have removed at this point in time. On your windows, regasketing and new barrel nuts/ bolts was an annual event to keep the water out. Third year I laid a bead of black sealant around the outside perimeter of the gasket before putting the window back on. Removed the excess and no more annual replacements. Other spots to check, the keel bolts. The shallow bilge is prone to corroding the steel washers and nuts on the keel bolts, clean them up and coat them well. You'll also find no fuel gage, I used a dowl and measured the tank, which you can easily access behind the head, and notched the dowl for easy reading. It only holds 7 gallons but the engine also just sips fuel. The volvo engine is a great engine and easy to service. Great boat, fun to sail, reef early and enjoy. I have a 331 now.
F
FMcNeil
alibi
Sep 12, 2007
14
Good Stuff
Thanks FMcNeil, That was helpfull. I will contact Beneteau.
alibi
Sep 12, 2007
14
Good Stuff
alibi
Sep 12, 2007
14
where is that service dept *grr
I can't for the life of me find Beneteau's parts and service department. anyone have a link?
alibi
Sep 12, 2007
14
C
chris
Here is the service department for beneteau
Todd Cranford Customer Service todd.cranford@beneteauusa.com Phone : (843) 629.5300 Fax : (843) 629.5329 Beneteau USA Inc. 1313 Highway 76 West
C
chris
Jun 29, 2004
1
- - Starbuck
headliner
check out http://www.beneteau235.com/ there is a section devoted to headliner problems and a searchable archive of discussion there.
