Noise
Hello Ted:Thanks for your letter. As I’m sure all of you would agree a “swish” to you may be a “gurgle” to me. So often when I’m working a “problem child” installation over the phone with a customer, I often focus my attention to the frequency of the “swish” and its reaction to the engines increase or decrease of Rpm’s. If the noise frequency increases as the Rpm’s of the engine increase, one can assume that the shaft, propeller and possibly the shaft bearing are the culprits. If the frequency is isolated to one range of Rpm’s, I begin to focus on mechanical componentry. Items like damper plates, couplings, alignment and even injector problems will cause noise which may only take place a specific Rpm’s and not full ranges. Of coarse when this is all taking place one needs to remember that one failing component may cause other components to sound off creating a multiple sound making it more difficult to isolate the problem child. Not sure if this one helps but maybe it gets you closer to hearing and understanding the noise. Sincerely, Kevin L. Woody
