I have just purchased my first sailboat ever and a 1981 hunter 30. I have a vibration in foreward gear only that is sometimes very severe. I know that the prop is out of true by 1/16th of an inch per the survey could this be the sole cause. Has anyone encountered this.The engine a Yanmar 2QM15 is smooth in neutrual and reverse thru the entire rpm range and the vibration starts in foreward gear at around 1000 rpm i do not have tack but that should be a close.
