Vibration from Keel?
  • Thread starter holtintulsa@aol.com
  • Start date
H
holtintulsa@aol.com
I recently purchased a 22 foot Catalina vinatage 1981. As the boat picks up speed, a humming vibration picks up from the bottom of the boat. I am assuming that it is related to the Keel or cable attached to the Keel. Have others experienced the noise and is there a solution. Thanks HOLTINTULSA@AOL.COM
Barry Broyles
Loosen Keel Cable
When the humming starts try cranking out some more keel cable and the humming should stop. It has always worked for me. Barry Broyles C22 # 1909 "Brighteyes"
john renfro
hummmmm
hello, yes the hum from the keel cable is normal, it lets you know when you are moving at a good clip. let some more cable out to take the tension off the cable and it will stop. john
Rick
Pretty kewl
Yeppers, We owned one for many years. That is very normal...The higher the pitch the faster you are going... Great for nite sailing...pretty Kewl. Rick
