Vibration at low rpm
93
Hunter 27 Lake Lanier, GA
Was able to dive on the boat this weekend and removed much of the past years growth on the bottom. The cutless bearing shows no slack and the prop is in good shape. The only thing I can think that might be causing the vibrations would be shaft alignment. How do I check shaft alignment?
I have also noticed this 1GM likes to be warmed up prior to departure and the vibration seems to disappear under higher rpm.
garyc
Oct 4, 2008
63
Hunter 27-76-84 mallets bay,vt
shake rattle & roll is the nature of the beast. It's one cylinder that why.
Dec 9, 2008
48
Hunter 30 Lake Ontario/Fair Point Marina, NY
I have a 2 cylinder that does the same thing. Any thoughts?
Paul F
Jun 3, 2004
827
Hunter 1980 - 33 Bradenton
Found that a three blade prop makes a huge difference in smoothing out the drive train.
Jeff
Sep 29, 2008
195
Hunter 33.5 Carlyle Lake in Central Illinois
I have a 3 cyclinder that doesn't like certain RPM ranges. I stay above or below those.
Jun 21, 2009
110
Hunter 27 Sparrows Point
Jim - I like to mumble Capt Quint's "Spanish ladies" (Jaws) during the low rpms. ;)
Also, my diesel mechanic says that warming those Yanmars in neutral does nothing for the engine. Running them in gear for 10-15 minutes keeps them happy.
