Vibartion
176
Hunter 25 -
I was sailing with my son last weekend. He asked me what was causeing a vibration sound.After investigation I believe it may be from the motor mount board on transom.
I'm using a 5 hp Tosatah OB now but I'm getting ready to attach a motor mount to allow me to use a short shafted 9.9 Johnson my brother gave me a few years ago.
Has anyone every experienced a vibration sound from the motor mount?
Jan 2, 2005
779
Hunter 35.5 Legend Lake Travis-Austin,TX
Centerboard boat?
If the boat has a centerboard, the noise is probably coming from the wire that controls the centerboard.
Jan 25, 2008
176
Hunter 25 -
Re: Centerboard boat?
Hi Honeyman....I have a line that raise and lower my swing keel. Thanks for your reply.
Jul 1, 2010
990
Catalina 350 Port Huron
In our case, we have a vibration noise at the ladder latch when using the motor. I'm assuming your vibration is when using the motor?
Jul 31, 2009
165
None None None
I think the 9.9 motor is going to be serious overkill. Consider the weight of this engine and that it may cause your boat to have a starboard list.
Jun 28, 2009
312
hunter 23 Lake Hefner
If you have bushings on your swing keel pivot, they might need replacing. If they are worn it could cause play in the keel. Just a thought.
mel22
Oct 1, 2010
66
Hunter 22 Lake Dardanelle
Another thing, is the 9.9 electric start with remote controles. If it is not just think how far down you will have to reach to reach controles.
To get motor to set at correct depth you will have to lower mount about 5 inches. I have a long shaft (20in) now and can not imagine reaching another 5 in. over the stern.
Just somthing for thought.
As for viberation in motor mount, I believe that is possible with a one cylinder motor and an older mount .
