My old Midland vhf started having problems transmitting. I started doing some research to buy a replacement and came across threads suggesting that a proper antenna and coax setup were much more important factors than the actual radio choice. I also saw other threads saying that fiberglass antennas and coax had a life span. I have a metal whip antenna mounted on my mast, not a fiberglass antenna, and am wondering if there is a life span for whip antennas? Should coax and or antenna be replaced periodically? I have gotten responses to my radio checks, the bridges opened when I called, so I know I am transmitting with the new radio. I receive the weather service. Is this as much testing as is done for most vhf setups? I am wondering what other methods some of you use to test the effectiveness of your radio. My anchor light needs repair and would probably have not worried about the antenna setup, since it seems to be working, except that I can kill two birds if necessary when I deal with the light.
