VHF Radio cable location in Mast ??
6
- - Portland, Oregon
I have a new 22 Mark II and want to install a mast mounted VHF antenna - where do you chase the VHF cable in the mast at the top- where does it exit at the bottom. Thanks Rik & Konnie
JIM B
Jun 27, 2006
107
Catalina 30 MKII ROOSEVELT AZ
USE LONG PLASTIC WIRE TIES
RIK, AS TO WHERE IT ENTERS OR EXITS---IF THE MAST HEAD FITTING IS SOLID, YOU WILL PROBABLY HAVE TO DRILL THE RIVETS OUT TO REMOVE THE MAST HEAD THEN DRILL A HOLE NEAR THE TOP FOR THE CABLE TO ENTER. IF THE TOP OF THE MAST IS OPEN-IT IS ONE LESS HOLE TO DRILL. AT THE BOTTOM DRILL ANOTHER HOLE FOR THE COAX TO EXIT. THE COAX SHOULD PASS THROUGH A RUBBER GROMMET IN EACH HOLE. YOU WILL NEED A COAX CONNECTOR AT BOTH ENDS SO YOU CAN REMOVE THE MAST. I RECOMEND YOU PUT A REALLY LONG PLASTIC WIRE TIE ON THE COAX ABOUT EVERY 10-12". LEAVE THE LONG TAIL ON. THIS WILL PREVENT A LOT OF NOISE CAUSED BY THE COAX BANGING THE INSIDE OF THE MAST WHEN THE BOAT ROCKS. OTHERWISE IT WILL BE A REAL SOURCE OF AGRAVATION WHEN SLEEPING ON THE BOAT. GOOD LUCK.
JIM B
Jun 27, 2006
107
THINK ABOUT A WIND INDICATOR
WHEN MOUNTING THE VHF ANTENNA, CONSIDER THE IMPLICATIONS FOR A WIND INDICATOR. SOME MOUNT RIGHT ON THE ANTENNA ITSELF. OTHERS, WITHOUT AN EXTENDED BRACKET WILL BE FOULED BY THE ANTENNA.
