I don't know of any non-portable
VHF that comes with an antenna. My guess is that you'll have to decide where the antenna is going to be mounted and then buy an appropriate one for that location. Most VHF antenna's mount at the masthead, where they are most efficient. Yet mounting the antenna there is somewhat difficult in that you've either got to go aloft or have the mast down in order to snake the cable inside the mast, then thru the deck, then to the radio itself. Some mount their VHF antenna on the stern or stern pulpit to avoid these tasks. If you choose this location, you'll probably give up a bit of performance as the height of the antenna is a key factor here.And while adding a RAM mic in order to have VHF capability from the cockpit will give you more power than using your current portable VHF, I think you will have the perfect combination without the RAM mic. I could have added a RAM mic on my Icom 402 but chose not to as (1) they are an expensive add-on and (2) I already had a portable VHF like you have. The portable gives you far more flexibility of use than does a RAM mic, but at the cost of reduced performance. I think that's a good tradeoff, at least for me.
