Tom
After my first (half) season getting used to the H260, I am ready to start drilling holes and installing equipment. This is to share my plan for VHF installation and request critiques and ideas for better alternatives.I selected the Standard Comm. Intrepid with the RAM (Remote mic) option and Shakespeare 5212CX masthead mount antenna. The antenna includes 60' of cable and the PL259 connectors and an L-braket for attaching to mast. RAM mic provides speaker, mic, and all radio controls in a handheld unit that is intalled remotely from the base unit.Install Locations:Radio -- above the table under and just aft of the mast base. Reason is that it is centrally located, out of head banging range and will provide shortest cable run to mast head. There is a cabin light near by, so I am assuming that running power back to the panel shouldn't be too difficult.Antenna install.Plan to run coax through existing conduit in mast. ** Any tips on how to best accomplish this are welcomed ** . Plan to remove base plate and head plate to gain access to ends of conduit and inspect for interference before drilling holes in mast. Hopefully these are attached with reusable fasteners and not rivets. Coax deck feed through: ** Any suggestions appreciated **. I want to minimize the numer of connectors in the coax line -- they introduce signal losses and potential sites for moisture to enter cable. Want to have the cable exit base of mast and go thru hole in deck (or snake around sea hood hinge) and connect directy to back of radio with out additional connectors.Will first investigate possibility of some how feeding cable thru front end of sea hood. Back up plan is to drill thru deck at base of mast and glass in a section of PVC or similar tubing to allow connector and cable to feed thru to radio below. The through deck tube will protrude above the deck about 1-2 inches to prevent water from draining into the cabin. Weather tight seals will be fabricated: one that is bonded to the coax at the appropriate location and one that will be used to cover the hole when the coax is removed.Power: Will feed power lines to existing panel and connect to spare switch/breaker.RAM mic: Will feed interface cable aft to proximity of battery compartment (starboard side) and place connector at base of aft end of cockpit seat near helm. Mic location to be in that vicinity, location to be determined: perhaps attach to starboard side stern rail to get it closer to ear level.Any and all feedback is welcome.Fair winds...Tom ... in New Hampshire
