Rick Appling
I have a 23' O'Day and primarily a trailer sailor. I'm in the process of installing a METZ VHF antenna on the mast. The installation seems to be pretty straight forward. However, I'm a bit leery about maintaining water tight integrity after drilling through the deck (near the foot of the mast) to install a through deck fitting (connect/disconnect for stepping and un-stepping the mast). Before I proceed I'm hoping to get some advice or lessons learned regarding installation and proper sealing of through deck fittings. Additionally, can the base plate on the mast be easily removed and re-installed? Removing the base plate will allow the antenna cable to be easily pulled through the inside of the mast. Any words of wisdom or experience on this type of installation ?
