Drop it right there
If you are in a sheltered marina you can easily drop the mast with one other person to help you. I have done htis several times in my slip. You need about 8 feet of clearance behind you plus the length of your antenna. Take the boom and boom vang off the mast and pu tbelow out of your way. Free up the halyards so you can easily move the mast forward once it is unstepped. Release the forward lower stays, put all the hardware in your pocket before it drops in the drink. Loosen the bolt at the base of the mast and have it ready to pull through the hole (not yet). Take any tension off the back stay. Release the forestay while your freind pushes the mast foreward. Your freind walks the mast back while you hang on to the forestay. Your freind carefully steps down to the seats from the cabin top. You press down on the base of the mast to relieve the tension, and pull out the bolt. The base of the mast will want to come up. You balance the base while the freind walks to the back of the mast, sliding the mast along their shoulder. You take the mast forward as this is done. When your freind gets to the spreaders they will have to lift the mast above their head to get on the other side. Pick a stong friend! To gain access to the top of the mast, bring it all the way forward about 4 feet past the bow pulpit. This will make you real popular with the others trying to walk up and down the dock. They will yell at you so it is best to have some snappy insults ready for this moment. Leave the mast here for a while as you and your freind go off to find liquid refreshment. Come back with a drill and drill an elongated hole (use an elongated drill bit) at the base of the mast and another at the top to let the cable in and out. Catalinas are supposed to have a black band somewhere near the top of the mast and near the boom. Now is a good time to put those on. Now what were we doing? Oh yes, attach your antenna bracket. I drilled and tapped some holes in the casting at the top of the mast to mount mine. Make sure you leave room for your wind vane to clear the antenna else you will never know which way the wind is coming from and you will have to sail by the seat of your pants and you will look pretty silly with your butt pointing up in the air trying to sense the wind direction. Connect your cable to the antenna. By the way, did you hear about the two antennas that got married? Lousy wedding but great reception!Ok where were we? It's time to raise the mast so walk it back and try not to get the stays caught on the winches cause it jerks the heck out of you and your friend's arms. Put the base in the step and try to remeber what you did with the bolt while your friend struggles to hold up the mast. Now is a good time to provide some encourage ment to your friend if they are still with you. Once the bolt is through have the freind push the mast up while you pull on the forestay. If the mast does not go up straight its because one of the other stays or a halyard in caught on something. Now is not a good time to find this out. Fasten the forestay, put the nut on the step bolt, put the forward lowers back together (remember the lok washers or nuts. Now you need to tune your rigging. But that is another story for another time.Jim
