Brent Headberg
The aluminum water tank in my 1990 33.5 finally gave in to corrosion, there wasn't a bonding strap to the tank and the welds finally split. I have just removed it and purchased a Vetus flexible water tank as a replacement ($95 vs. $350 for plastic). The bladder comes shipped from the factory with a 5/8" supply and 1-1/2" filler connection. I have 2 questions:1. Will the 5/8" supply fitting work with it mounted on top of the bladder?2. Does a bladder need to be vented?I am going to install this bladder under the v-berth and secure it to the old fiberglass tabs that use to hold down the top of the old aluminum tank. I cut the tabs along the edge of the old tank, so there's a short tab still attached to the side of the hull on both sides. This will be a temporary water tank until I can have a custom plastic tank made to fit the space under the v-berth. I'm not sure how many gallons the old aluminum tank held, but I would guess around 40 gal. The new Vetus flexible bladder holds 42 gallons.If anyone has any input, I'd appreciate it.Brent HeadbergS/V Elena Luahttp://www.elenalua.homestead.com
