Vesper AIS and Garmin interface
Mar 21, 2004
2,175
Hunter 356 Cobb Island, MD
in the wonderful land of NMEA interfaces. Trying to interface a Vesper XB-8000 to my Garmin network which is NMEA 0183. Trying to get the AIS information to show up in the chartplotter.
Has anyone out there accomplished this?
Tim R.
May 27, 2004
3,626
I have connected a Camino AIS transponder to a Garmin 3206 with no problems.
What model Garmin?
Make sure you have the speed set properly(38,400) and some Garmins require the AIS data to be on one of the two 0183 ports to work properly. Also check your Vesper RXneg 0183 connection. I believe all Garmins require that to go to ground.
Mar 21, 2004
2,175
Well I think I have found my answer which was provided by Vesper support.
My Garmin port #1 is the high speed 38400 port. I hooked up the vesper NMEA(-) port to the Garmin when it should go to ground. Had the (+) port correct. Will be a few days before I test this out.
Just love wiring NMEA....-)
Tim R.
May 27, 2004
3,626
Having the neg wire connected wrong is the number one problem connecting NMEA 0183 devices to Garmin. AFAIK, Garmin is the only manufacturer to this.
Mar 21, 2004
2,175
Tim, letting you know I got the wiring done today before the next cold wave hits.
IT WORKS... hooked up to port 1(38400)
Mar 21, 2004
2,175
well that was fun today. expecting 7-10" of snow by Monday evening.
Went to the boat and rewired the entire NMEA harness for the Icom 604, 802, DSC and Vesper AIS. Must say it wasn't so bad after laying everything out on paper!! It was just a matter of cutting wires and soldering the LITTLE fine wires to accept connectors.
But everything works now. Have GPS info to both radios and DSC, AIS being display on the Garmin chartplotter....
Now to bottom painting and waxing the hull...
Oh yea, got a problem with the VHF cable or antenna.... SWR is at 3 - not good, but i'm not going up the mast YET...
May 23, 2004
3,319
Oh come on Jim, Tomorrow would be a great day to go aloft! LOL
I am so ready for spring.
