I purchased a new water pump and pressure vessel last year to boost up my pressure water system yet I had a minor leak somewhere that was elusive to me. I checked all fittings, fixtures and the two tanks, but could not find anything. It was not until I decided to take a look under the quarter berth area where the hot water heater nests to check that location out. There it was leaking from a broken plastic "L" fitting coming from the hot water discharge line. The fitting was wasted and when I tried to remove it it broke in three places. That brought up the question of who installed plastic fittings on a water heater, especially a hot water discharge line? It was the original Seaward Model that came standard on the Mark II. Catalog photos show a new unit with no fittings attached, so was it the Catalina factory? I am not a plumber so I do not know code, especially for 1988, but all I talked to said they should have been brass fittings for those hoses. I did replace those plastic inserted pieces this morning with two new brass units and attached the hoses. All is well and the system is running better and not leaking.
Gain from my experience here. If you have the older Seaward hot water heater (6-gallions) check your cold in line and hot discharge fittings to for plastic "L" fittings for any heat damage, weakness or burns. I purchased inexpensive 1/2 inch brass fittings with hose barbs at Home Depot for a simple replacement and used pipe dope as well. Turning the AC switch off was of course the first step.
Granted the unit is 24 years old and may have nine lives so I guess I am lucky here. But maybe someone can offer some info. on the proper water heater intake and discharge fittings.
Just another Catalina 30 Mark II fix it experience. :dance:
Bob
'88 Mark II
Breezin II
Bob
'88 Mark II
Breezin II
