Vertical battens w/furling main
Nov 19, 2009
289
Hunter 45CC Ft Pierce and Abaco Bahamas
This question goes out to any of you that have a selden furling main, and a Doyle (or any other) sail with the vertical battens. Do you have any issues with the sail "hanging up" coming out of the mast? The owner of the boat I recently bought said he had the issue and then removed the battens and now the sail unfurls and furls fine with no difficulty. I can't believe Selden would put the combo together (Doyle full battened with the in-mast furling) if it caused a problem. This is on a 45CC. Thoughts?
Ron
Yes. I did have problems with the sail vertical battens and the Selden in mast furling. Focusing on the battens the originals were full length, round and would not go easily into the mast slot. At the suggestion of my sailmaker, we shortened the batten pockets and got new battens which were a little flexible in the fore-aft dimension but still stiff enough in the vertical dimension. After that the in mast furling worked much better. There has been a lot written on these forums on the subject of in-mast furling pro and con.
Nov 19, 2009
289
What about having a flat(er) batten made from fiberglass instead of a round one.
I also wonder how horrible the sail shape is and how badly the sail performs without the battens in the sails
Feb 16, 2012
198
Hunter 45 CC Alamitos Bay, Long Beach
Ron
Ron,
I have the same problem with my 2005 Hunter 45 CC, Doyle Main Sail, full length round battens. In the later 45 CC's (maybe 2 to 3 years after ours) they went to the much shorter battens, and that seems to have solved the problem. Not sure if the shorter battens are flat or round.
Jeff
Sep 22, 2009
134
Hunter 36 Seattle, WA
I have round verticals on our H36. I have heard of others who have changed out the batten shape with success. I decided to work with them, and after a year of reefing and shaking out in various conditions, discovered the best techniques to employ. Any problems that I now encounter are due to halyard tension issues. Use of the rachet system for fueling and reefing is critical in wind conditions above 15kn.
A battened sail is cut to be used with battens. The roach sags terribly without them.
Nov 19, 2009
289
Ron,
Jeff
Mine is a 2007 and I just bought it and it's on the hard until spring, but I believe I heard the owner say they were full length battens that he removed. He said a sail shop did something with the pockets I think also. So if they battens are shortened, where to they sit in the sail? Are they from the leech down? I think the owner even said he was considering getting the leech trimmed, and I don't think I want to do that. I think I'm more inclined to finding much flatter battens and keeping them shorter.
Nov 19, 2009
289
StuartSW
Any problems that I now encounter are due to halyard tension issues.>>
Meaning the halyard was not tight enough?
A battened sail is cut to be used with battens. The roach sags terribly without them.>>
Yeah that's what I'm afraid of. The leech line I'm sure won't make much difference in that
I'm sorry I didn't explain very well. The full length battens were round. The new shorter ones were flatish. The shortened batten pockets started at the leech and extended maybe a 1/3 the way down the sail. It didn't appear that ending the battens in the middle of the sail was much worse than ending horizontal battens in the middle of the sail. Without battens the leech would sag badly.
Likes: RWSlater
Sep 22, 2009
134
Yes on the halyard. I had a racing partner who subscribed heartily to the concept of bagging the mainsail (I.e, slacking the halyard) for downwind work, a questionable advantage on a B&R rig. If he or I ever forgot to haul her back up tight before our upwind work, the furling would inevitably jam as a result.
Likes: RWSlater
Patrik
Apr 1, 2008
66
Hunter 356 Stockholm
I have three short round battens and have not had and problem with furling or unfurling the main. Se attached Picture
Likes: RWSlater
Aug 26, 2007
268
Hunter 41DS Ventura, California
This subject has been covered in the past but I'll repeat our experience.
We initially had the same problem with jamming when furling or reefing. We tried removing the battens but sail shape was not good. Replaced the battens with new ones but no help. We finally solved our problem by simply adjusting the rigging and modifying our reefing/ furling procedure.
When furling, adjust the boom with the topping lift so that the sail retracts parallel to the mast (reefing stripes equal distance at top/bottom of mast ). Once you find the right trim, mark the TL. Always turn directly into the wind when furling or reefing unless winds are very light.( Not a big deal unless you are racing ). We found that having the wind just to starboard so the sail rides against the port side of the mast slot works best. Keep very slight tension on the outhaul as you furl with the furling line. Winching is not required. This is easiest with two but can be done single handed as well. We have been using this technique for several years and it works great for us.
Our boat came rigged by the dealer with the reefing lines backwards so the sail furled the wrong way into the mast so check that first! Good luck.
Nov 19, 2009
289
OK so after talking with the previous owner, he describes how the sail would jam coming out and going in, and after 4 trips to the sail shop to try and correct the issue, the shop suggested removing the battens and recutting the sail to have no roach. He said the furling works fine and can be done by hand pretty much without winches. So I guess the problem is solved. Not sure if it creates other issues but with the headsail being the power sail, it should be ok. He also said he can sail in to the 20's of wind and not get much weather helm. So we shall see how it goes in the spring when the boat gets splashed
