Doyle Zenith Main experience
Jack W. and anyone else with a Doyle Zenith Main system, you need to talk to your Hunter dealer (or local Doyle loft) and obtain from them two very important documents that have the title “Sailing with your Doyle Zenith Full Batten Furling Mainsail.” They are relatively new documents published in June this year by Doyle, specifically for the system being installed on Hunters (and others similar). Follow the instructions EXACTLY as they have them and it should resolve many, and hopefully all, of your furling problems. It did for us. If you can not get a copy of the documents, e-mail me directly (look me up in owners’ directory) and I will send you the PDFs. We have a 2005 Hunter 41 with the Doyle vertical batten system. The boat sails wonderfully with it and the sail holds a beautiful shape. Boat does especially well in light airs. I am very pleased in the performance of the sail. I can not compare performance using a sail without those battens since we got the boat new with them.When our boat was first commissioned in April, the sail would jam at a batten almost every time when unfurling. It never jammed when furling. The local Doyle loft was on our boat several times and made some alterations, but the biggest difference (fix) came from following a more managed technique in both furling AND unfurling this sail. This is where the documents described above come in to play. So, bottom line, these Doyle Zenith Full Batten Mains are more sophisticated, will give you a gain in performance over a standard furling main, but may require a more managed unfurling/furling effort following Doyle’s instructions. For us on this size boat and the way we crew (mostly me doing all the work) and where we sail (Chesapeake), the work required is much less than that required with a classic main. Best wishes Carl and Jule, you will enjoy your new boat.
