I am new to a Venture 25 that I bought and have various questions. I am hoping for information from other Venture 25 owners.
1) I am replacing the pulleys (sheaves?) at the top of my mast on a 1976 Venture 25 because the pulleys are deteriorated. They are originally pinned into the top of mast block. Does anyone know where I can buy replacement pulleys/sheaves? I have attached photos of the pulleys already removed and sitting on top of where they were removed from. Dimensions are approx. 1-1/4" diameter x 1/2" wide with center hole 5/16" w/o the sleeve. The center hollow sleeve /center pulley overall width is approx. 9/16"
I may not be using the correct terminology as I describe this. Since I have not yet rigged and/or set up the mast and run any of the ropes/sheeting thru the top of mast, does anyone have photos or explain how for the mainsail uphaul line runs thru the masthead pulleys? Does it run completely thru the masthead in one side/out the other? What size line goes thru the pulleys?
On the photos, there also is another pulley with what it looks like to be an uphaul line. I wonder if the former owner installed this other pulley instead of replacing the pulleys as I am trying to do? Any ideas?
2) the masthead light wire comes thru the mast thru the masthead block area and the wire would seem to interfere with the line that goes thru the mast head area. Is the masthead light wire going to be in the way? Photos attached.
3) there are two attached brackets near the top of mast that I have no idea what they are for. Has anyone seen these before/or know what they are used for? Photo attached
4) Also Does anyone have any info or photos on the kickup rudder rigging to be able to secure it down while sailing? Is there any pulley setup on the rudder to help raise the kickup segment?
Any help, feedback and photos would really help and would be greatly appreciated.
Thank you in advance.
David M
David M
