I have removed my keel but all that remains is a steel plate with additional steel plates welded on either side. The leading edge used to have some epoxy and fiber glass on it but now there is only steel. What should I do to rebuild this? I am planning to replace the leading edge with Marine Tek and then build up the balance with body putty and/or fiberglass. Should I cover the rest with a thin coat of Marine Tek or what or nothing. How wide should the keel be and how much space should there be around the keel when it is in the storage well?
