venture 17 trailer wheels
Jul 14, 2019
57
macgregor venture 17 meridian,ms
got a 1974 venture 17,has original trail rite trailer,did not have wheels on it,what size wheels and tires would be best to use on the trailer? or which size were originally used, 4.5x5 lug,did they use 13,14,or 15 inch
576
Hunter 30t 9805 littlecreek
Picture would help or especially how many lugs u have. Harbor Freight has best selections of rim's and tires Overtons has cheap prices as well. A few really old trailer had a big 4 or 5 pattern. They were like 1' apart you can still get those from trailer supply stores. Just need tires rated for weight of boat + trailer
Take a large piece of paper. Jam it over the lugs to get a pattern. Then get the largest diameter tire with that lug spacing that you can fit under the fenders.
Nov 28, 2017
6
Venture V-17 1143 Ludington, MI
My 1970 trail rite trailer for my Venture 17 came with F78x14 tires, today you will find the 205/70 should be a close replacement and easily found. I'm not sure that there is enough clearance under the fenders for a 15 inch wheel. I have a 5 lug wheel and it is pretty standard, you can just measure this before you order the wheels.
Jul 14, 2019
57
thanks that's the answer i have been waiting for
Likes: Tsatzsue
295
1970 Venture by Macgregor 21 Clayton, NC
As for the bolt hole pattern, my 1976 Dodge Aspin spare work as a spare on the trailer that came with my 1970 Venture 21. If that helps
