Vented Loops
Terry Stewart
Our marine head appears to have a siphon created where water still fills the bowl (about half way) when the level is switched to the dry position. There is a vented loop with an air valve you can access in the cabinet above the head. Venting this loop does not solve the problem. Where is the other vented loop and how do you access it?
Nov 12, 2006
256
Catalina 36 Bainbridge Island
Vented Loop
There is usually only one vented loop on the flush water intake side. It should be on the hose from the pump to the head. The hose from the through hull to the pump will not have one. After switching to dry bowl there will still be some water entering from the hose with the vented loop. The 'other' vented loop should be on the hose to the holding tank, but this isn't needed on the 'head to holding tank only' system installed by Catalina. You would need one if you discharge directly overboard (not legal within 3 miles of the coast).
JOHN DEWEY
VENT LOOP
I HAVE A 2004 MODEL 310 AND HAVE ONLY ONE VENT LOOP. WHAT YEAR IS YOUR 310? WE NEVER DRY FLUSH BUT RATHER USE THE FRESH WATER FROM THE SHOWER FAUCET TO FLUSH WITH FRESH WATER JOHN TIC TAC III
